RE: battery information need
I'm pretty sure that you're looking at 5200 mAH. IF the battery is connected in series, then the voltage and the mAH should both be the sum of the cells, I believe.
A great article on batteries can be found here:
[link]http://www.masportaviator.com/ah.asp?CatID=2&ID=146[/link]
