RCU Forums - View Single Post - QHOR Construction error help.
Old 05-27-2003 | 10:38 AM
3D-Flyer
Default QHOR Construction error help.
Hi all,
Been working on my QHOR, my first. I have made 2 errors so far and need some advice.
1. I have a wing span of 20.5 inches instead of the normal 24 inches for a OS .25 MAX. Will this cause the plane to be out of control with such a short wingspan?
2. When cutting the angle on the aelerons, I made a very bad cut and so I cut them flat again. This only gives me 1 inches of control surface on the aelerons. Will my QHOR still roll right with such small aelerons?
Everything else is going as planned. The 3/4 inch channel seems to twist awefully easy and am thinking of shortening the length and adding something inside the channel to stabalize this. Opinions?
Thanks!
-Brandon
