RE: Big Stick 40 or 60
I'm interested in the Big Stick 60 (Great Planes) and would like to know if anyone has the dimensions of the firewall. I'm planning to put a Saito FA-100T (Four stroke horizontally opposed twin) on it. The engine doesn't use the horizontal lugs for mounting like you would an OS .46AX, instead it mounts vertically to the firewall using a mount similar to a bell housing in concept.
The holes in the vertical mount at 50 mm apart (width) and 70mm apart (height).
Anyone know if that will fit on the front of the Great Planes Big Stick 60?
