RCU Forums - View Single Post - Pipe Setup Question
Old 10-26-2008 | 04:03 PM
pe reivers
Default RE: Pipe Setup Question
Hmmm...
If you can slide the pipe over the header, there still seems some header left methinks?
High rpm engines have the pipe starting right at the exhaust port outlet. The manifold then is just long enough to allow a sealing ring, butno more. In a side exhaust engine of course one needs a little more header to get around the bend
