ORIGINAL: 46u
As long as you have an adjustment where you can limit the end points in both directions running a digital servo will be fine but just make sure about your end point adjustment or it can be a costly mistake.
Well I plan on upgrading my radio soon also. So if I can adjust my EPA I should be fine? If I can't will it burn the servo out?
