RC 1/8th Scale Buggies Discuss the ever popular category of 1/8th scale rc buggies in this forum!
which steering servo
Old 10-28-2008 | 09:46 PM
  #51
46u's Avatar
46u
Default RE: which steering servo
You ever notice on a standard FM when you put on and take of the glow plug starer how the servos glitch? With 2.4GHz they are steady as a rock. With standard FM you cannot cut your radio at a track unless you are racing and on the frequency board. With 2.4GHz NO problem as it finds it own open frequency. This is just a few advantages with 2.4GHz. In 3 years of using 2.4GHz the only run away I had was when my receiver pack got low.
With the React made by Nomadio with a push of the button you can check your RX, TX battery voltage and engine temperature. If the voltage gets to low on the RX or TX the TX goes to beeping and vibrating same if the engine temperature gets to high. The main thing I do not like the DX3.0 the only built in fail safe is for signal loose and does not work for low RC battery like the React. This is how I had my only run away with 2.4GHz in 3 years.
I really like my Nomadio React only problem is they do not keep up with the demand and getting extra RX can be all most impossible much of the time. A lot of the time getting the whole radio system can be hard. But you can use some of the slower Spektrum RX with the React.
Old 10-29-2008 | 04:17 PM
  #52
ace9213's Avatar
ORIGINAL: 46u
So you say the react is really good. I'm going to go and research it.
Old 10-29-2008 | 04:24 PM
  #53
I've heard great things from guys who own the Nomadio radios. A little rare in my area since no one carries them around here, but I have read some very good things about them.
Old 10-29-2008 | 10:02 PM
  #54
ace9213's Avatar
http://www3.towerhobbies.com/cgi-bin...?&I=LXTT13&P=0
This seems like a good servo. Anyone ever use one or hear good feedback from it?
Edit: Also I am interested in a rechargable battery for my buggy. I know nothing about them. What should I look for in a good battery?
Old 10-30-2008 | 08:28 AM
  #55
ORIGINAL: ace9213
It doesn't say it's a digital, but I think that all the better servo's are digital nowadays.
Old 10-30-2008 | 04:28 PM
  #56
ORIGINAL: ace9213
I like the look of that one as well. Does anyone have any experience with airtronics or that servo? Reviews anyone?
Old 10-30-2008 | 04:48 PM
  #57
musclecar64's Avatar
ORIGINAL: Echelon
ORIGINAL: ace9213
I don't think that one's digital.
Old 10-30-2008 | 10:35 PM
  #58
ace9213's Avatar
Your right, it's not digital. That's why I want it.
Old 10-31-2008 | 03:41 AM
  #59
I use a FM radio system with EPA etc. In my 1/10scale electric buggy I use an analoge servo. I can't even adjust the trim, cuz I think because the servo is analoge, so forget about EPA. So if you're going to use a digital radio system, maybe you can't use trim and EPA etc. Maybe you analoge servo's won't burn as fast as digital, but they still can break/burn when EPA isn't adjusted properly, right?
Maybe you won't have this problem, but I do.
Old 10-31-2008 | 04:09 PM
  #60
ORIGINAL: Echelon
I never changed the EPA on my current Hitec servo and no problems so far.
Old 10-31-2008 | 04:40 PM
  #61
most cordless phones run on 2.4GHz.lol
Old 10-31-2008 | 05:57 PM
  #62
ace9213's Avatar
well i'm picking up that airtronics servo!
Old 10-31-2008 | 08:14 PM
  #63
ORIGINAL: supermod
Mine are on 5.8
Old 11-01-2008 | 01:21 PM
  #64
the airtronics servos are quite good. dont let the fact that they arent digital fool you; they are strong and fast. digital servos have slightly better resolution, but they arent inherently faster and they do burn more electricity. the airtronics servos are very good; i have three. strong, durable, and dont burn much power.
Old 11-01-2008 | 02:53 PM
  #65
lol igot 1 to from radio shack
Old 11-01-2008 | 03:18 PM
  #66
46u's Avatar
46u
ORIGINAL: Echelon
Is your FM computerized radio? If so and it is like my React you can change the settings for antologe and digital servos.
Old 11-01-2008 | 03:21 PM
  #67
46u's Avatar
46u
ORIGINAL: ace9213
Being it is not digital this should fit your needs for not since you do not have a radio with EPA. Even with antologe servos EPA will keep stress off the servo and make them last longer. When you can try to update your radio system.
Old 11-01-2008 | 03:22 PM
  #68
46u's Avatar
46u
ORIGINAL: UF DUB
One other thing about digital is they are MUCH better at centering to the same point every time.
