RCU Forums - View Single Post - Computer Tx and HBK2
Old 10-27-2008 | 06:36 AM
Disney1's Avatar
Disney1
Default RE: Computer Tx and HBK2
Makods:
You pitch curves should be for 0 degrees pitch up to 50% throttle and then from 0 to 10 degrees from 50% to 100% throttle.
Your throttle curve should be o0% at bottom of the stick and 100% at the top fo the stick with the graph at a 45 degree angel. This is in normal mode and should get you flying. You can play with the pitch curves from there.
I have a DX6i and do not know how many program points you have on pitch and throttle curve. But the curve numbers are the same.
R[8D]N Sr
