RCU Forums - View Single Post - Pipe Setup Question
Old 10-27-2008 | 02:48 PM
brjensen71's Avatar
brjensen71
Default RE: Pipe Setup Question
OK, time for more details, I starting to wonder if the pipe I have is sized correctly. The goal is to get max RPM on high pitch prop.
The engine is a Super tigre 90, it has had boost port timing raised to match the inlet ports. The inlet and boost ports have smoothed. The crank timing changed to gain more RPM, and the piston modified uncover the ports.
I have been using a 15cc Macs pipe and header, and an APC 10X10 on 10% nitro fuel.
So far I have been able to get 15300 rpm from the motor.
I have included my data so far
File Type: txt
