RCU Forums - View Single Post - CRRC 40cc kit
Old 10-28-2008 | 06:07 PM
  #36
cantw8tofly
Default RE: CRRC 40cc kit
O.K. I think i got this thing figured out.
Here is what i did:
Moved the throttle servo back next to the rudder and elevator servo's
installed an rdj7j resistor plug.
Solderd a ground wire from the cap to the engine block. [ read that one in the forums ]
Installed a hose clamp on the cap to hold it on securely . Also after reading your post the other night i checked and found that i had not been pushing the plug cap on far enough. I just didnt think that i would have to use much force to put it on. But when i checked it i was able to push it on another 1/4" futher than before.
I ranged checked it as best i could in the yard with the plane tied down. Next is to find an open spot so i can really range check it.
I will try and do this tomorrow and let ya know how it goes.
Also i wanted to thank you guys for all your help.
cantw8tofly
