RCU Forums - View Single Post - Pipe Setup Question
Old 10-28-2008 | 07:46 PM
brjensen71's Avatar
brjensen71
Default RE: Pipe Setup Question
While using the MDS muffler with and adapter, I did get modest improvements each of the modifications, see my earlier post with the test data. Once I started using the Pipe RPM started to pick up.
I did start using an OS carb, not because I dislike ST carbs, I can make them perform with any muffler ( I use the tricks on pe reivers'es website ). I simply get more RPM's at max throttle, and I can use it with a remote needle ( BVM type ).
Now, based on the feedback I am getting, I am wondering if I need a different pipe.
I included a picture of my test stand, you can see the MDS muffler and adapter.
ID:	1061093   Click image for larger version
ID:	1061094   Click image for larger version
ID:	1061095   Click image for larger version
