ORIGINAL: tkg
Just bolting on a CH RCXL or anybodys RCXL will make for an engine that is way out of time and will run poorly.
The CH conversion kit is 104.95 and included a new prop hub with a retimed keyway
FFIW
CH sells the CH RCXL ignition single for 79.95 not 100. AND the timing chip and plug wire our to our specs
If a person gets the timing right with the RCXL...why should it run poorly? Thanks capt,n
