RE: Screwed upspinner rubs on cowl
Putting a spacer behind the mount is the best solution, but you could TRY putting a plywood ring behind the backplate. The ply should be soft enough to allow both the backplate and the thrust washer to bite into it.
If the backplate is smooth, you might want to glue a sheet of sandpaper to the front of the plywood.
