RE: Screwed upspinner rubs on cowl
I did put a piece of 1/8" lite ply that I sanded down and really torqued it so the teeth on the drive washer and spinner backplate would make an indentation. Do you think I should then put CA on the plywood to harden it. Taking if off of course before I put the CA on. I did cut the plywood in a circle to match the drive washer.
