RCU Forums - View Single Post - G-Booster harness wiring question
Thread
10-31-2008 | 05:20 PM
1
marc s
Jan 2007
3,294
1 Post
farnborough, , UNITED KINGDOM
Currently about to fit the G Booster and ECU into a build and wanted to know if there are 'accessories' available for shorter cables that run between the ECU and turbine? I would really like to loose over half the length of each rather than try to stuff them in somewhere where they will just get in the way.
I did remove the heatshrink from the power cable harness and was a little shocked at the poor quality of the soldering to the multiplex plug and socket, it was hard to work out what wire was soldered to what pin as the little pcb board used to do the job had solder blobs so close to other contacts it looked as if they were joined[X(]
Has anyone shortened these cables, the power one I guess is easy, the black ribbon cable not so - any advice please.
Few pics of the soldering...
marc
Reply
Like
marc s
View Public Profile
Send a private message to marc s
Find More Posts by marc s
View iTrader Profile
