RCU Forums - View Single Post - AquaCraft V24 Gas Vee RTR Boat - Is this a good boat.
Old 11-01-2008 | 02:34 AM
  #92
01VIPER27
Default RE: AquaCraft V24 Gas Vee RTR Boat - Is this a good boat.
I had a hairline crack on the cylinder head which was replaced with no question within a week and I live in Toronto, Canada. Oh yes we have igloos here
Get a Stainless Steel 3 Blade 70 Mil Tatur Prop
Get a Stainless Steel 3 Blade 68.5 Mil XXX Prop
from http://www.voodooprops.com
Want to plane higher and faster? Remove and replace your stock tank with an IV Bag and tuck it under your radio tray. This will give you better CG as the boat is nose heavy.
Want to turn better and faster? Fill in the space between strakes on the 3rd step and 2 inner strakes on the 2nd step. This will allow you to turn tighter without hooking or doing a barrel roll by being able to skim or slide over water in and out of tight turns. Do not grind off your strakes, the 8 Oz of fiberglass fill will give you a lower CG.
Put a Zen 260 PUM with clutch and water pump into it and you will have a big smile on your face. Add a CCP10 exhaust kit from http://www.ccracingengines.com and you will have one ear to ear.
When I grow up I will buy a Nimbus hull from MHZ with a Z drive or RCM drive.
Did I say I like my V24 then, now and in the future?
