Sullivan Pull-Pull
Sullivan has a pull-pull system.You get 30 feet of .032(1/32") stainless steel cable that's brass plated for easy soldering,and 30 feet of the yellow nylon housing.It's part # S522 for $8.95.The Dubro 4-40 and 2-56 cables will work with the Sullivan yellow nylon housing if you don't want to solder.
