Here is an earlier thread on the Pulsar. Rainedave had kit plans at the time. He'll probably chime in with what he knows.
http://www.rcuniverse.com/forum/m_62..._pulsar/tm.htm
I bought a much flown Pulsar off RCU a few months back. I've only seen one kit in about 3 years of watching ebay. This one had been flown so much that all the tread was worn off the tires (or maybe it just took a long while to get off the ground). There was some damage to the wings which I have since repaired by resheeting the damaged areas. I removed the firewall and need to do some patch work where the rear exhaust engine/pipe cut into the fuse. I've made all new tail surfaces. Generally it's a solid plane and it will restore just fine.
If you keep watching, you should be able to pick one up. I believe kits were also made by Flair.
Jim
