RCU Forums - View Single Post - PC 9
Thread: PC 9
Old 11-01-2008 | 01:55 PM
dmurf
Default PC 9
Hi guys,
I was given a used PC 9 from a very good friend with all hardware installed plus os engine.The problem is its a try-cycle and the nose wheel does not work properly. The nose wheel is loose and the screw securing the nose wheel on is hard to get to because the os engine is installed inverted and the same screw is stricking the engine when you turn to the left.
Im not a fan of these nose wheels because they give trouble and was considering converting the PC9 to a TAIL DRAGGER]. Is this a good idea or does anyone have any other ideas.
Thanks Damien
