RCU Forums - View Single Post - PC 9
Thread: PC 9
Old 11-01-2008 | 09:49 PM
hogflyer's Avatar
hogflyer
Default RE: PC 9
When you pull the engine, also pull nose gear out. Check it to make sure there are flats ground on the wire where the set screws will seat against the gear wire. When you put it back in, make sure you use Loktite on the threads.
The reason for the flats is to prevent the wire from turning under stress on the ground.
Hogflyer
