RE: JetJoe OWNERS thread
check yor battery and double check all plug ins. Start sequence should be glow on -you will here a buzz if the glow plug is drawing power from the ecu. next the gas solenoid turns on- I don't use one just a check valve to motor. check rpm sensor wire It sould not run near you glow wires and motor wires as it pick up rf noise. twisting the glowplug wires helps too. check temp probe with a lighter watching display it should extend 1/8 " to 1/32" in to tail cone.check starter wires maybe it broke off starter I use a mini deans in line and can plug in to battery to check. make sure large plugs to ecu do not have a broke wire and are pluged all the way in.
