RCU Forums - View Single Post - DL-50 engine
Thread: DL-50 engine
Old 11-02-2008 | 06:39 PM
  #3210
dlenginesaustralia
Default RE: DL-50 engine
ORIGINAL: fritzdecat
Does the Da ignition fit the DL engine?
A DL ignition will work on a DA, you have to swap the pickup sensor over though as well. So I suspect the reverse would be true also.
Though not sure why you would do unless you had it laying around spare as a DL ignition is a lot less $ than a DA one. No performance increase to be gained except maybe you can run a DA ignition on a 6v pack without a volt reg.
