RCU Forums - View Single Post - DL-50 engine
Thread: DL-50 engine
Old 11-02-2008 | 10:51 PM
  #3220
mstam1971
Default RE: DL-50 engine
ORIGINAL: dlenginesaustralia
You can spin the throttle arm 180 as it has the screw holding it on. But the choke arm is a press fit on the end of the shaft. No screw to remove so you have to grind/break it off and do the steering arm thing if you need to get at it a different way.
Normally just spinning the throttle arm 180 makes the choke easier to get as it frees up access to the lever, so it can be left as is.
Cheers
Correct. Choke can't be reversed in a normal fashion, there also shouldn't be a need.
