RE: Velox CG HELP
balanced mine...gear down. nose slightly pointed down using shoe strings on the front carbon anti-rotation pins. I used the recommended control throws. The Velox needs a LOT off up elevator mixed into flaps (about 20%) . Make sure you have high rate elevator. You can easily run out during landing !!
