RE: Velox CG HELP
???? Down elevator mix? Better check that, as mine is set the same as John Agnew (see this post/thread [link=http://www.rcuniverse.com/forum/fb.asp?m=5956753]http://www.rcuniverse.com/forum/fb.asp?m=5956753[/link] I mixed 15 mm up elevator for full flaps and I saw no change in attitude. I also raised the front of my Falcon about 5mm on the front straps to give a little more down thrust. Flew great.
My CG is set slightly nose down on the forward anti-rotation pins as well.
Dan
