RE: Velox CG HELP
This is how mine's set up...
CG - 5mm aft of the C/L of the wing anti-rotation pin
Aileron movement - 14mm each way (measured at the tip - no expo...gives the very soft aileron I like)
Elevator Movement - 30mm each way (12% expo)
Rudder movement - 25mm each way (measured at the top - no expo)
Flap travel (measured at outb'd flap/inb'd aileron position):
Take-off: 20mm with 9mm up elevator trim mixed in
Full-flap: 35mm with 11mm elevator trim mixed in
(so that means there's 20mm up elevator trim required with full flap travel)
Cheers,
Dick
England
