ORIGINAL: gaRCfield
Futaba does not have the software that controls only one receiver per memory bank (#1, #2, etc) so what that means is that if you've bound the Rx to the Tx and they are both on, you will be controlling the Rx no matter what model you've selected. So, you want to get all your settings for that plane squared away under one model bank and give it a name.
There should be a model reset feature if you want to clear everything out and start again.
Once you've got that stuff squared away, make sure you have the right servos plugged into the right channels. next, check the direction and reverse as necessary. Then go to your endpoints and adjust as necessary. This should give you a decent place to start from.
Also, make sure your switches are all off or at a neutral position, or wherever they should be.
Make sure your mixes are off too.
Maybe some more info about the rudder would help: does it move one way when you push the stick on way, and move the same way when you push the stick the other way, or does it only move with one input and not move with opposite input?
Hollo gaRCfield
I have all the above figured out.
Now I have another problem.
Everything was fine except the rudder was to much to the left with the setting at zero (OFF)
I adjust that and now all the servos are chattering and all but the rudder are showing a mild flutter.
The RX came wired so I assume the RX is OK since all semed good until I made the rudder adjustment
For some reason i'm not receiving the post in mail even though I have it selected to be notified so i'll check the site in appx 15 minutes.
Thanks for responding
Vegas/
