RCU Forums - View Single Post - MK Beetle Build
Old 11-05-2008 | 01:36 AM
  #66
T Brooks
Default RE: MK Beetle Build
Hello Everyone
Cees
sorry, I didn't see your reply till just now.
I had planned to do the wheel wells before putting on the bottom sheeting as you suggest. On the plans it shows the well partially taking out one rib rather than being right between two. Before noticing this I bent the wire legs to sit between the ribs but then found that it sits decidely nose down when on the wheels. I will have to make new wire legs. With that said I decided to do as MK show on the plans and put the wells in after bottom sheeting.
I have cut the openings for the two aileron servos and the baasic retract area.
I have also started to dry fit trailing edge section between the root and ailerons.
Cheers
Tarquin
ID:	1065870   Click image for larger version
ID:	1065871   Click image for larger version
ID:	1065872   Click image for larger version
ID:	1065873   Click image for larger version
