Originally posted by MinnFlyer
To go from a 2.5 wheel to a 3" wheel will give you 1/4" more height (3 - 2.5 = .5 /2 = .25). Instead of buying new wheels, see if you can extend your nose wheel by 1/4" and add a 1/4" block between your main gear and the fuse.
How would I do this? If you mean I should loosen the little allen bolts and pull the nose gear wire down 1/4", then I don't have wire to spare (after just looking). And wouldn't a block just move the wheel forward? I'm not getting it, Minn.
