RE: D-lo's Engine/Boat Mod Thread............
i then started to reassemble the block, in went bearings, cam drive gear, the cam/housing, and the piston/sleeve, and finally the crank/housing. i timed the cam bearing using the 'dot' to get top dead center. i found this info in the 'engines' section of this website................... oh, and a shot i missed of the heads valve seat/bowl area cleaned up and ready for assembly...
