RCU Forums - View Single Post - ASP 4-stroke run in
Old 11-05-2008 | 11:25 PM
Delta3
Default RE: ASP 4-stroke run in
If you do run with Castor in your fuel make sure you buy the "de gummed" version. Takes a lot of the gunk out of the process and still protects the engine. Brian Winch did the warranty work on a Magnum engine of mine and they are the same as ASP
