RCU Forums - View Single Post - Velox CG HELP
Old 11-06-2008 | 02:52 AM
SinCityJets
Default RE: Velox CG HELP
ORIGINAL: Sparhawk
???? Down elevator mix? Better check that, as mine is set the same as John Agnew (see this post/thread [link=http://www.rcuniverse.com/forum/fb.asp?m=5956753]http://www.rcuniverse.com/forum/fb.asp?m=5956753[/link] I mixed 15 mm up elevator for full flaps and I saw no change in attitude. I also raised the front of my Falcon about 5mm on the front straps to give a little more down thrust. Flew great.
My CG is set slightly nose down on the forward anti-rotation pins as well.
Dan
It took 5mm under the front strap to get it to fly straight?!?
How much speed are you getting out of the Falcon on the Velox?
