RE: hpi rush problem
If it's got good compression then your motor is fine.Is your motor turning over or is it slipping?If it is slipping then I'd say you owb needs a good cleaning or needs replaced.Make sure glow plug is good and glow ignighter is fully charged.Are you priming the motor?
