RCU Forums - View Single Post - What is the same diameter but longer than a 4 40 screw
Old 11-06-2008 | 09:11 PM
combatpigg's Avatar
combatpigg
Default RE: What is the same diameter but longer than a 4 40 screw
Machine screws into a plastic mount is a waste of time, use socket head sheetmetal screws.....they will never back out. If the holes in your mount are wormed out, shift the engine forward enough on the mount to drill new pilot holes for the sheetmetal screws. For .40-.50 sized engines I drill out the holes in the engine lugs to accept #6 sheetmetal screws to pass through.
