RCU Forums - View Single Post - What is the same diameter but longer than a 4 40 screw
Old 11-07-2008 | 08:32 AM
HighPlains
Default RE: What is the same diameter but longer than a 4 40 screw
I use nothing smaller than 6-32 hardware on most engines and just tap the mounts. 6-32 taps and drills are much easier to deal with than 4-40, much less likely to break while tapping the beams. On some engines you may need to open up the engine mounting holes as CP said.
