I cannot seem to understand all this so I'm going to add the links with my question and hopefully someone can help me out...
It says that it is only compatible with micro connectors... does this mean the my Hitec HS 65 MG, HB servos are going to need a special hook up at the end so the can connect to my Rx....
http://www3.towerhobbies.com/cgi-bin...?&I=LXUDS7&P=0
Here are the things I thought I would need, I believe they are micro connectors.
http://www3.towerhobbies.com/cgi-bin...?&I=LXMHA5&P=7
Will these hook up to the servos either, how do I go about getting this to work, or should I look into another 2.4ghz Rx, if another Rx is what I need that will be unfortunate... the only other ones are 129.99 and up... so that should set me back another month or so
