CG Question
Not sure where to post this, but here I go. I finished a kit and it is time to balance, so I set it on my Great Planes CG Machine and in order to get it balanced properly as recommended, the battery has to be placed in the rear and it balances perfectly. So I velcro the battery in place set the model on the floor and it sits on its tail (it is a tri gear not a tail dragr). In order for it to sit on the tri gear I have to move the battery forward but then on the CG Machine it becomes nose heavy. Has any of you eno****ered a situation like this and what do you recommend to correct this?
TIA
