Aresti Thrust
The firewall in the Aresti is SUPPOSED to have built-in right thrust. Mine is very noticeable - at least 2 degrees. If your firewall is 90deg from the centerline, it's defective OR they changed the design.
Have you checked your wing incidence? Could your wing be warped? Mine is as gentle as a kitten - even at slow speed.
