El Mod with asiatam recoil unit
Hi Guys
Wonder if anyone can help me a little problem with my elmod install. I am doing a Panzer 4 with full elmod. I also have the Asiatam all in one recoil unit fitted. Problem is that when the elmod booster/tls and blaster are fitted everything works fine and the barrel recoils along with the main gun sound BUT the barrell does not return to the start position after the recoil. I can make the barrell return by pulling back on the left stick after I have fired the main gun but it should recoil and return in one movement. I have the elmod installed with my origional Heng Long boards and transmitter if that makes any difference. The recoil I purchased came already fitted to the turret with all wiring in place with the exeption of one wire which I have to connect to the negative feed to the main board which I have done.
help !!
