Pull-pull is the same as G2. If you are flying 2.4 then you won't need the cover over the cable otherwise everything else stays the same including crossing the cable
ORIGINAL: kmtranmd
I have the Gen II manual for my G4 100cc yak. Manual says to cross the pull-pull cable and use Sullivan Gold-n-rod 504 over the cables to block RF. What change/update is there about the rudder pull-pull set up not noted on the manual that came with the plane? I just got the plane 10 days ago.
