RE: Pattern Plans
Guys,
it might be a browser configuration issue. Mac or PC doesn't make a difference but if you don't succeed with one browser try another (e.g., Firefox, Safari).
The TIF files are 150-200 dpi full res scans and weigh about 500-1000 KB so JPEG compression was applied in the scan (uncompressed TIF would weigh considerably more). The best approach to working with the files is to vectorize them into PDF for example. Then they can be marked, scaled, pushed and stretched at will without quality loss. My PDF's are actually converting at just about the same weight which is quite remarkable but this is the first time I convert raster to vector image using the method I did. Of course these are flat files (no layer info has been retained), unlike say the PDF's I offered of the Tiporare some weeks back.
If anyone needs these in PDF format, I can email them given their size. Just PM me with your address.
... and Pete, thanks again!
Cheers, David.
