RCU Forums - View Single Post - Opensource CDI ignition
Old 11-11-2008 | 04:01 PM
  #216
Bigboat
Default RE: Opensource CDI ignition
The url doesn't work, Artikel-Nr.: 516643 - 62 at www.conrad.de.
It's hard to say if this core will work.
Normaly HF-cores will be 10 Mhz and more.
If the core can't handle the ocsilator frequentie, the ocsilator will shut-off.
But the price isn't to high to test this core.
BTW, if the freq isn't enough to charge the C to the right Voltage it can be also the transistor.......low HEF-type !
Some built the ocsilator with a FET, I don't try it yet, but maybe this can help to raise the freq and the Voltage.
