RE: Opensource CDI ignition
Futterama,
Do you know if the 100 ohm resistor in Vcc is necessary (presumably it helps stabilize power to the controller)? If needed, what is the smallest wattage resistor you been able to use? The LT3750 and Coilcraft DA2032 look pretty good, or are you using the larger DA2033/2034?
John
