RE: Opensource CDI ignition
I order about 10 or 12 read to use transformers, but all stop working around 10 - 15.000 rpm.
Normaly the transformers will be used for DC/DC conversion, 12 Volt to 240 Volt.
They don't need a high frequentie like we do.
The FLPS-transformer will work without conversion, but you do modify our schematic.
The Voltage from the FLPS will be about 250 or 350 Volt, but it's to slow.
You have to change the C on the FPLS to get a higher frequentie.
