RE: Need HELP!!!
Hook up 2 Servo Aileron non Flaperon
#1. Go to DEVICE SELECT and rotate the
roller until you are under AUX2 (on the bottom of the screen), Press the roller and INH AUX2.
#2. Go to WING TYPE: NORMAL and rotate the roller until you are under AILE, Press the roller and select AUX2.
Hook up 2 Servo Elevator
#1. Go to DEVICE SELECT and rotate the roller until you are under AUX3 (on the bottom of the screen), Press the roller and INH AUX3
#2. Go to WING TYPE: NORMAL and rotate the roller until you are under ELEV, Press the roller and select AUX3.
NOTE: You may have to REVERSE AUX2 OR AUX3 or both depends on the hookup of the linkage.
NOTE: Connect Right Aileron to Aileron and Left Aileron to Aux2. The same for the Elevators Right Elevator to Elevator and Left Elevator to Aux3.
