Yes, the plane came with the motor mount brackets installed. and a nose ring that helps support the cowling also you can really see the thrust angles when you put a spinner back plate on when you do the first fit up of your motor [8D]
It is scarey to think and to trust the manufacture, when they put the amount of down thrust and side thrust in already
these things are built in a jig assembly so they are set up pretty damn close for the first flight or two
they also have pieces of triangle stock on the sides for reinforcement. [&o]
You have to cut out some of this triangle mount pieces to line up the motor in the center of the nose ring
they used their own style of vibration damping mount
Now if you try to change this motor mount system to a another mount system it is going to take some work on your part
you will have to cut off their mount system the brackets are tied back threw the fuse leave the inside parts alone [sm=47_47.gif]
