RE: Fox Engines
BH, that engine can't too old, it has the newest EZJust carb, just set the airbleed screw about halfway across the inlet hole, find the peak on the HS needle and you're good to go. The carb is a metered carb with an airbleed trim to compensate changes in fuel, props, weather etc.
