RCU Forums - View Single Post - GAS/GLOW HOW TO....
Old 11-16-2008 | 06:04 PM
  #68
Lnewqban's Avatar
Lnewqban
Default RE: GAS/GLOW HOW TO....
ORIGINAL: av8tor1977
Basically, the answer is no. The reason being that...
That is not to say all is lost. There have been some people experimenting with Gas/Glow mixes in glow engines here in the forum but with more oil content. Do a search and some threads should pop up with more info. The only other caveat would be to watch for overheating. A tightly cowled glow engine running on a gasoline type mix could overheat unless proper cooling air ducting was achieved. The gasoline in the mix burns hotter and does not have the inherent cooling effects of methanol.
AV8TOR
Thank you, Av8tor!
