Lanier 80" Cap 232 - Canopy coming off
its not the greatest quality but it flys good and tips when building put your rudder servo under where the pilot figure would go and use pull-pull for the rudder control i used a nelson bellcrank and it works good call and talk to don at dons hobby and he'll set you up i have that combo (Cap ARF/Fox 3.2) and it flies good oh and i hover about 5/8 throttle with a mejzlik 21X10 i just got a Mejzlik 22X8 and my engine is getting more power as it breaks in (i only have about 3/4 gallon through it) well good luck if you need help with anything just post a topic and you'll get replys good luck!!!
David
