RCU Forums - View Single Post - ZXX engine interference
Old 11-17-2008 | 10:22 AM
  #39
jster1963
Default RE: ZXX engine interference
UNBELIEVABLE!! How can I keep getting multiple failures?
On a whim, I put the igniter on my other engine in the basement; same thing. So I hooked it up to my multimeter to check for low voltage. It was TOO HIGH! It was reading 10 VOLTS, not 1.2 volts. The glow plug portion of my power panel has failed.
Therefore, I was putting full 12v battery power to the glow plugs. It must have blown them right away. That is why the other igniter didn’t work either.
I will replace the glow plug, use my regular glow plug igniter and give it a try. It is 30deg outside with light snow right now. If it warms up a little today, I will give it another try.
Nitrohog, I will call heliproz. Tony, I’m all for global warming. I voted for it. I hope to have my chopper up and running so I can put it away until spring.
Thanks again guys, and more later…….jster
p.s. My pics are too big so I am resizing them and will post in a few mins.
