RE: Charging batteries
It should work fine. It will just charge at 3A instead of the 3.2A max that you could charge it at. According to the manual, it uses the standard CC/CV charge method for LiPo packs, and has a 3 hour safety timer. There is no mention of it actually limiting the total charge (mAh) it puts into a pack. You should easily be able to fully charge a 3200mAh pack in less than 3hrs with a 3A charge rate.
